 Post subject: 2016 A24 prop
PostPosted: Tue Jan 26, 2016 10:16 am
I have ordered a 2016 A24 with the 450HP motor. Has anyone ran this setup for wakeboarding loaded heavy and if so what is the best prop? I don't want to be too low and loose all my top end but i want to be able to get out of the hole quick loaded with 4500lbs and 10 people.
I have searched everywhere and haven't found a definite answer.
 Post subject: Re: 2016 A24 prop
PostPosted: Tue Jan 26, 2016 5:42 pm
I'm in the process of getting a new prop got my 2016 t23. I run about 4500 also and have been told by everyone to get the Acme 2315 or OJ945 I decided on the OJ but you want go wrong with whichever one. I currently run the 1235 acme.
PostPosted: Fri Apr 29, 2016 8:50 am
For surfing or wake boarding? I run the 2249 and works great for surfing but wake boarding it doesn't like it but you have more power so it would Probably be fine?
PostPosted: Mon May 09, 2016 10:46 am
I ended up going with the 2249. With the 1:72 ratio and the 450 HP, it does very well . I am running about 4400 RPM at 24 mph loaded with about 4,200lbs ballast and running the wedge.
The wake is awesome by the way.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 59 guests
