It is currently Tue Oct 13, 2026 5:02 am
jason427
Post subject: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 12:44 pm |
| Boater |
We have had our 2015 T22 for a couple months now. We are limited in water depth where we use the boat. 10-14' We originally ordered boat with standard PNP option (450's in back, + bow bag under cushions). Wave was nice but I was having trouble staying on it (I'm 6'1" 210lb) We always run at 10.6 with above setup.
I swapped out rear bags for 750's and also added another 600lb bag on TOP of cushions and filled everything up. Wave seems nice but not sure how much better or if we should be changing our speed?
Any rule of thumb on this?
Thanks, Jason
ndahlberg12
Post subject: Re: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 12:51 pm |
Your in shallow water. Not much more you can do. Boat is running out of room to displace water.
jason427
Post subject: Re: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 12:57 pm |
| Boater |
So could my wave actually be getting worse due to not enough depth? It almost seems that way... Jason
vanamp
Post subject: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 1:33 pm |
Yes, water depth makes a big difference. I'm usually in a deep lake but surfed a lake with "bump" that we were crossing where depth went from 20' to 10'. You could feel the push get sucked out of the wave and once we got to other side of bump wave would get good again.
I was surprised how much of a difference it made.
ThatGuy
Post subject: Re: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 2:25 pm |
Joined: Thu Jan 08, 2015 6:29 pm Posts: 538 Location: Ohio
You may also want to list slightly towards the side you're surfing on. I find that helps. Like a couple hundred lbs difference, if that. But yeah, shallow water = no bueno.
_________________ 2015 T22 - SOLD
r33pwrd
Post subject: Re: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 2:58 pm |
Joined: Sat Jun 06, 2015 10:35 pm Posts: 1181 Location: Sammamish WA
Get your surfer out there and play with speed, he or she should easily be able to pick the right speed for them.. my ideal speed will vary .8 mph from day to day. That being said I surf from 11-11.8 (on speedo not gps) and we will vary the same person to person on the same day.
_________________ -2015 A24 - 409 HP - 2249 Prop - 1100 rear sacs - 950 front sac - 290lb rider with Red Rocket and Phase 5 Quest
Raimie
Post subject: Re: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 3:22 pm |
Joined: Wed Dec 18, 2013 7:27 am Posts: 239 Location: Harsens Island, MI
I like a slight list on my T22. I have all the passengers sit on the port side and if I am light on people I run a 350lb sack on that side. We typically run 10.6.
_________________ 2018 T22 Previous Boat: 1998 Malibu Sportster, 2014 T22
3oh2rider
Post subject: Re: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 5:30 pm |
I weight my t22 evenly. I run 750s in the back. Wedge down 650 up front and surf from 7'-10' of water. It def makes a huge difference when you actually have water. However a decent wave is still obtainable
3oh2rider
Post subject: Re: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 5:31 pm |
Oh and def slow down til like 9.8/10 on port side wave and like 10.2/10.4 starboard (shallow water speeds)
dezul
Post subject: Re: Surf speed VS. ballast question. Posted: Mon Sep 21, 2015 6:31 pm |
We typically run at 11mph on port and 11.2mph on star. We slam it with the wedge down and 600lbs in the bow. It surfs like a beast.
Users browsing this forum: Google [Bot] and 36 guests |
