It is currently Sun Mar 29, 2026 2:07 pm
 Post subject: Ballast and sacs filling by themselves
PostPosted: Fri Jun 05, 2015 3:37 pm
I have a 2013 a20 and my center ballast and my front sac are filling by themselves. Has anyone else had this problem? What should I check for the cause of the problem?
 Post subject: Re: Ballast and sacs filling by themselves
PostPosted: Fri Jun 05, 2015 5:05 pm
Pretty typical in my experience. I will occasionally drain them if I'm cruising somewhere a long way away. Better to have them filling than draining IMO!
2014 A22
PostPosted: Fri Jun 05, 2015 5:10 pm
By the way drain both front and center together. Otherwise they will bleed over into eachother.
2014 A22
PostPosted: Fri Jun 05, 2015 6:15 pm
Is there any way to prevent this from happening?
PostPosted: Fri Jun 05, 2015 11:55 pm
I asked my dealer the same thing. You could reach under your flooring and shut the ball valve each time. But I decided that's a huge pain and would never do that versus just flipping the switches to drain occassionally
2014 A22
PostPosted: Sat Jun 06, 2015 4:34 am
Sadly no, I have pulled my boat out of the water with 800lbs of water in the bow and I had no idea
