It is currently Fri Oct 16, 2026 12:48 am
mogey5
Post subject: SERVICE REQUIRED on display & cruise issues Posted: Thu Apr 23, 2015 8:22 am |
| Newbie |
Joined: Sun Mar 08, 2015 9:27 am Posts: 20 Location: Austin, Texas
i ran into a couple issues on the lake yesterday.
1. when starting to pull a surfer, the boat went back down to idle and "SERVICE REQUIRED" was on the display. in then quickly went away and boat was functioning normal. common issue?
2. the cruise was having a lot of trouble setting even in flat water for surf speeds. it would beep (set) then beep over and over again. prop issue? i'm currently running a 1235 with about 3k pounds. it gets up to speed no problem though.
thanks
idahosurf
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Thu Apr 23, 2015 9:22 am |
Joined: Sun Sep 15, 2013 12:18 am Posts: 362 Location: Boise, Idaho
What year boat? They were having trouble with the cruise last year.
_________________ 2015 Malibu 23LSV, Former 2014 A22 and 2002 Tige 23V
mogey5
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Thu Apr 23, 2015 9:26 am |
| Newbie |
idahosurf
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Thu Apr 23, 2015 8:00 pm |
I would call the dealer and ask them about it. if you are close to the dealer, maybe run it in and have them test it.
dezul
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Thu Apr 23, 2015 8:17 pm |
Sell it to me. I will give you 40k for it right now.
kingranch
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Sun Apr 26, 2015 8:51 pm |
| Newbie |
U can look at the error if it is a code just push both gauge buttons and hold for 3 sec and the menu pops up..scroll down to the codes and see if one logged
alexandera
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Sun May 03, 2015 7:45 am |
If it was a MIL error it has to do with emissions. Mine has done it 3 times, but only at idle. I bet it's an O2 sensor and am not worrying about it until I go in for break in service.
_________________ -aha-
alexandera
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Mon May 04, 2015 11:26 am |
Looked my code up. Elevated Exhaust temperature tier 1 for both manifolds. Going to dealer anyway. Will let you know.
mogey5
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Mon May 04, 2015 2:23 pm |
| Newbie |
i checked my codes but there were none logged. it's happened a few times since my last post as well. i just dropped it off at the dealer, i'll post back when they figure out what's wrong.
alexandera
Post subject: Re: SERVICE REQUIRED on display & cruise issues Posted: Mon May 04, 2015 8:22 pm |
It will not log them... You have to catch them while the error is active. Luckily I was able to catch a photo of mine. I will keep everyone posted too. Again, mine has only happened at idle speed.
Users browsing this forum: No registered users and 73 guests |
