It is currently Tue Sep 16, 2025 1:17 am
[ 3 posts ] |
Author |
kx250frider617
Post subject: Water leak update Posted: Thu Sep 11, 2014 10:59 pm |
Team Axis |
Hey guys, I just want to make an update on my water leak fix that I found. I have the all white 12' brostock boat that I had a leak that I couldn't find. Now my boat is sort of a hybrid where they installed 1 1/8" ballast hoses and pumps. Even the tanks have the bigger fittings. Anyway, the rear drain pumps have a T fitting that connects the tank drain and one of the pNP bag lines. That T fitting was for the 3/4" fittings that came stock on axis at the time. The guys just gooped on a bunch of silicone, trying to make it work. Basically, I grabbed the fitting and it pulled out of the threads with vey little effort. I then installed a 1" PVC threaded T fitting with the appropriate adapters and it cures the problem.
For those that have been back there, I was able to thread the pump straight onto the new T fitting, effectively removing one of the factory adapters. At the same time, I was able to gain quicker drain times from upgrading the factory 3/4" fitting.
It may just be isolated to my single boat because it was a special situation, but it's worth checking if you have a bad water leak.
Top |
TallRedRider
Post subject: Re: Water leak update Posted: Fri Sep 12, 2014 10:52 am |
Newbie |
3/4 inch fitting, 1 1/8 hose.... I guess they were in a hurry to get the boat out of the factory? That is just poor workmanship.
Good work on troubleshooting everything and tracking it down.
Top |
kx250frider617
Post subject: Re: Water leak update Posted: Fri Sep 12, 2014 12:08 pm |
Team Axis |
Yep. I sort of laughed when I saw it. Someone clearly knew it wasn't right but went for it anyway. Luckily, I enjoy working on the boat as a little get away hobby. I could definetely see how other customers wouldn't be too happy.
Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 103 guests |
