It is currently Wed Oct 21, 2026 8:34 am
 Post subject: If you have GPS / Cruise Control issues on your Axis
PostPosted: Thu Jul 31, 2014 6:58 am
If anyone has issues with there GPS cruise control acting flakey mine was not fully snapped in causing it to go fast then slow down while wakesurfing, I would keep reseting the Surfgate and the Settings via on screen thinking that was it but what i needed to do was, unscrew plastic under drive side and snap that GPS wire fully in place, it was connected but not fully snapped before. it was working but when it hit a wave it would slightly disconnected for like 5 sec, causing it to freakout the boat!
Hope that helps someone.
 Post subject: Re: If you have GPS / Cruise Control issues on your Axis
PostPosted: Thu Jul 31, 2014 3:45 pm
Explain what that GPS looks like. I was just poking around under the dash and saw what I thought was the GPS. It was near the toggle switch for the paddle wheel.
2014 Axis T22
PostPosted: Sat Aug 02, 2014 10:17 am
it was a black box about 3in to 3in had a wiring harness that should be fully clipped in.
PostPosted: Sat Aug 02, 2014 8:40 pm
Yup. That's what I saw. I'm going to check it.
2014 Axis T22
