It is currently Tue Sep 16, 2025 4:38 am
 Post subject: How to tell if boat has a cat?
PostPosted: Tue Jul 15, 2014 7:12 pm
Engine was just replaced on my 2012 Axis A20. The manifolds were on back order but the dealer had two "Malibu" manifolds that I was told were the exact same but black instead of silver. Not wanting to wait any longer I stated that if they were the exact same other then the color to go ahead and install them. Now that I have the boat home and have examined it, I do not see the cat logo that my previous manifolds had on them. How can an untrained eye tell if there is a cat present or not?
 Post subject: Re: How to tell if boat has a cat?
PostPosted: Tue Jul 15, 2014 7:39 pm
Load up a pic and I'll tell ya
PostPosted: Tue Jul 15, 2014 7:52 pm
Boat is an hour away wont be able to get a picture till the weekend.
PostPosted: Tue Jul 15, 2014 9:01 pm
if its perfectly round in circumference then it has catalytic converters, if its more oblong in shape then it probably doesn't
PostPosted: Tue Jul 15, 2014 10:39 pm
Here is a non cat manifold on my 2010
PostPosted: Tue Jul 15, 2014 10:49 pm
Non cat manifolds will probably be cast iron and have a textured feel on the surface, cat models will likely be cut out of stainless steel and have a large section 6-10" long where the catalyst will be installed and they usually have O2 sensors in the rear of the manifold by the hose connection similar to this pic
PostPosted: Wed Jul 16, 2014 8:03 am
probably better with out them in my opinion. esp with ethanol in the gas
PostPosted: Wed Jul 16, 2014 12:41 pm
You should see 2 oxygen sensors about 8-10 inches apart on each manifold. no oxygen sensors no cat
PostPosted: Thu Jul 17, 2014 6:02 pm
I would have prefered CATs for little fresher air surfing, but my non-cat has not ever been a problem.
PostPosted: Thu Jul 17, 2014 7:56 pm
Thanks guys. And yes that was why I was concerned for the surfing. I will check on the weekend but I recall there being two O2 sensors so I am sure the Cat is there.
Users browsing this forum: No registered users and 145 guests
