It is currently Fri Jan 10, 2025 7:07 am
[ 6 posts ] |
Author |
Fishn4four
Post subject: 2014 Bluetooth problems Posted: Mon Jun 30, 2014 5:07 am |
Team Axis |
Joined: Mon Dec 16, 2013 4:52 pm Posts: 170 Location: Tri-Cities, TN
Has anyone else noticed "noise" coming from the stereo when using the Bluetooth input? I have sound pack 3. I just had the first 20 hour service and the dealer checked it out and said he disconnected the rca's and reconnected them and it sounded fine. I tried it when I got home and it was still the same. Just for sh#!'s and giggles, I went to radio shack and bought a ground loop filter and installed it between the rca's of the bluetooth and the head unit. No change. I'm going to crawl under the again today and see if I can locate the bluetooth module and make sure the connection is tight. Otherwise, maybe the module is bad? Anyone else with an idea?
_________________ 2014 Axis T22
Top |
ridebutter
Post subject: Re: 2014 Bluetooth problems Posted: Mon Jun 30, 2014 7:07 am |
Team Axis |
Top |
Fishn4four
Post subject: Re: 2014 Bluetooth problems Posted: Mon Jun 30, 2014 7:37 am |
Team Axis |
Yeah. 2 batteries and it does not change with engine. It stays the same even in accessory mode.
Top |
Fishn4four
Post subject: Re: 2014 Bluetooth problems Posted: Mon Jun 30, 2014 7:38 am |
Team Axis |
I also unplugged the rca's and plugged a 3.5mm jack in and plugged my phone to that and it worked perfect.
Top |
ridebutter
Post subject: Re: 2014 Bluetooth problems Posted: Mon Jun 30, 2014 9:06 am |
Team Axis |
Could be a bad module. With it not changing from battery to battery, or engine off or on, I don't think you have a typical ground loop issue.
They are pretty simple little devices. I'm surprised how much they charge for that option.
_________________ Ridebutter Wakeboard School Cove Wakesurfers
Top |
Fishn4four
Post subject: Re: 2014 Bluetooth problems Posted: Mon Jun 30, 2014 10:04 am |
Team Axis |
Cool. Thanks. I am going to try and follow it up to the module later and see if I can see how it's wired in. If I can I would like to disconnect it and hook to another source and see if the problem persists. Then I'll know. ..
Top |
[ 6 posts ] |
Users browsing this forum: No registered users and 69 guests |
