It is currently Tue Sep 16, 2025 3:05 pm
 Post subject: Cruise Control Delay
PostPosted: Mon Jun 16, 2014 12:31 pm
Just picked up my A22 on Friday, and I'm seriously impressed. Coming from my '09 210, I thought there would be things I missed, but so far I'm really happy.
One issue though, when trying to adjust the cruise speed there is a delay. It doesn't matter if we are at cruise speed, or sitting idle, the delay is the same. It is really annoying, and apparently there is a fix for it, but I'm not sure what it is.
Thanks!
Ridebutter Wakeboard School
Cove Wakesurfers
 Post subject: Re: Cruise Control Delay
PostPosted: Fri Jun 20, 2014 8:07 am
what do you mean by delay? sitting idle? do you mean the time it takes for the number to change when you toggle the switch? When I toggle it is about a second per change or I can hold it down and it moves faster. Please elaborate and maybe some people can help you out.
PostPosted: Fri Jun 20, 2014 8:51 am
Yeah it takes a second when I push the switch, I have been on an older axis and it changes instantly. The tach just has a delayed response to the switch.
"Sitting Idle" I was referring to setting the speed before I went under power or changing the speed while under power, it makes no difference.
Cove Wakesurfers
PostPosted: Fri Jun 20, 2014 1:42 pm
Same delay on my 2012 A22. Not sure why its delayed but im already used to counting my clicks.
PostPosted: Fri Jun 20, 2014 9:46 pm
Yep same on my 2012
PostPosted: Fri Jun 20, 2014 9:52 pm
Anyone not experience a delay?
Cove Wakesurfers
PostPosted: Mon Jul 14, 2014 5:49 am
I noticed that my 2014 T22 does the same thing. Sometimes it changes instantly and other times it takes forever for the changes to register. its when we switch from wake to surf or surf to wake that I notice it most.
2014 Axis T22
PostPosted: Tue Jul 15, 2014 6:21 am
I have noticed with my 14' that you have to ease into the throttle especially at lower speed settings on cruise. I use to be able to gas it all the way and it would just pick it up on my 2010 but not on this one.
Try just using enough to get on plane and then give it a little more to set cruise.
PostPosted: Sat Aug 02, 2014 6:03 am
Anyone found a fix yet?
Users browsing this forum: No registered users and 77 guests
