It is currently Sat Oct 31, 2026 2:27 am
 Post subject: New Axis Boat
PostPosted: Thu Dec 01, 2011 8:08 pm
Im going this weekend to get a new A22 and have a couple of questions. Can anyone tell me if it will fit under a 10 foot carport? The boat has tricked out with 18" wheels. How good are the factory Tower Speakers and also how is the stock wake?
 Post subject: Re: New Axis Boat
PostPosted: Thu Dec 01, 2011 8:30 pm
If its ten foot exactly its going to be very close. My carport is a little over ten ft and the light on the tower is close to the top. Sorry... I would measure it but I am away from where it is stored.
The stock tower speakers are fine but you wont be able to hear them while wake boarding. But are good for listening around the boat. I ended up getting some in-expense HLCD speakers and putting them in the MTX cans.
Stock wake? Meaning the three hard tanks, plus wedge?
PostPosted: Fri Dec 02, 2011 11:03 pm
There was a post on here about changing out amps, or adjusting/tuning the amps properly helps make the stock tower speakers work well. Its been mentioned that from the factory the amps are not set up at all. I dont have tower speakers so I cant really help.
as for the stock wake...as ed did, we need more info. stock tanks only, with wedge, with plug n play? stock tanks only, very small but will be clean as low as 17mph. stock tanks plus wedge, still small but clean, still can ride pretty slow 18mph. once you start adding some plug n play ballast, it gets really big really quick. ELC's wake with wedge, stock tanks, and factory pnp set up at about half is really big and nice.
PostPosted: Thu Dec 22, 2011 6:47 pm
The total height with the tower folded down on the trailer is 6'10". I haven't measured mine with the tower up.
PostPosted: Thu Dec 22, 2011 7:05 pm
It fits
PostPosted: Fri Dec 23, 2011 8:03 am
I'm with ya brotha. I need to add the PNP system too. Have been with the stock ballast for over a year now and it's time to step it up.
