It is currently Fri Apr 24, 2026 7:26 am
 Post subject: Do PNP bags come stock if you order you'r boat with the PNP
PostPosted: Sun Dec 22, 2013 7:57 pm
if so what size?
 Post subject: Re: Do PNP bags come stock if you order you'r boat with the
PostPosted: Sun Dec 22, 2013 8:09 pm
No. You have to order them.
PostPosted: Sun Dec 22, 2013 8:23 pm
I wish :D
PostPosted: Sun Dec 22, 2013 10:37 pm
I'm going to get the 1100's. Anyone have reason to go smaller? You can always just fill halfway.
PostPosted: Mon Dec 23, 2013 6:41 am
On my 2010 w/1100s I had to reinforce the engine deviders or they would flex and pop out of the tracks. I would definitely go with the 1100s again, but imagine the 750s don't require this.
PostPosted: Thu Dec 26, 2013 3:13 pm
The Pnp option from the dealer is just the hose connections. It is a must option and I think most all dealers are ordering them now with the option on all the new boats they order from Axis. I see more BFI 750 combos over any other combo sold thru Boardstop.com.
PostPosted: Thu Dec 26, 2013 7:06 pm
I like my Straight Line Sumo 600's. Just another option.
PostPosted: Sat Dec 28, 2013 9:19 am
1100s... no question. That way you have the weight if you need it. And follow morrisdl's suggestion; works like a charm.
-aha-
PostPosted: Sat Dec 28, 2013 1:12 pm
Those that are running the 1100's. Are you also running with the wedge down...?
If so how long does it take to plane out?
I am running the SUMO 600's and when I fill them to capacity along with center tank full and front 950 full with wedge down and 4 people in boat it takes a bit to plane out. Not sure I would ever get there running the 1100's.
Running the 1235 prop.
Wedge up and I have no problem as it pops out of the hole pretty fast. However with wedge down it drags.
PostPosted: Sun Dec 29, 2013 9:53 pm
You'll need the high torque prop (acme 2315) to run 1100s.
Users browsing this forum: No registered users and 106 guests
