It is currently Fri Sep 25, 2026 6:57 am
Gryphon
Post subject: dead on water Posted: Sun Jul 07, 2013 2:40 pm |
I am out on river right now, key is turning freely and not starting boat, any suggestions?
SDUKES
Post subject: Re: dead on water Posted: Sun Jul 07, 2013 2:47 pm |
Check you emergency cut off lanyard.
SDUKES
Post subject: Re: dead on water Posted: Sun Jul 07, 2013 2:48 pm |
Is the engine turning over (cranking) but not starting?
SDUKES
Lanyard is located below the shifter red coiled cord.
SDUKES
Post subject: Re: dead on water Posted: Sun Jul 07, 2013 2:50 pm |
Make sure your shifter/throttle is in neutral
Gryphon
Post subject: Re: dead on water Posted: Sun Jul 07, 2013 2:57 pm |
Yes checked, both, it's the ignition switch, it will turn 360 degrees
Gryphon
Post subject: Re: dead on water Posted: Sun Jul 07, 2013 3:12 pm |
Which two wires can be used to jump start the boat
SDUKES
Post subject: Re: dead on water Posted: Sun Jul 07, 2013 3:23 pm |
Should be a red or orange and back or other dark colored wire.
AJWest
Post subject: Re: dead on water Posted: Sun Jul 07, 2013 11:21 pm |
Was your ingnition switch just loose from the back allowing the key to spin?
csf
Post subject: Re: dead on water Posted: Mon Jul 08, 2013 10:52 am |
Same thing happened to me last fall. My switch had to be replaced.
Users browsing this forum: No registered users and 70 guests |
