It is currently Sun Nov 22, 2026 4:26 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2, 3  Next
 Post subject: Looking for help picking a surf sac
PostPosted: Fri Mar 22, 2013 3:37 pm
Hey guys I need help picking out a fly high fat sac for my rear v locker I want the biggest one you can fit in there with binding hard plastic Engine shield. I demo the 1100 surf sac the other day but it seemed to big and I was thinking it would brake engine shield any help of what you guys are using to get the biggest surf wave would help
 Post subject: Re: Looking for help picking a surf sac
PostPosted: Fri Mar 22, 2013 4:09 pm
750 prolly..i use the standard 400lb that expands to 550. and i throw gear in there as well to add more weight but i normally wakeboard. but i use the 1100lb surf sac to throw on the seats when i surf. and it makes a great wave. i just posted a few pics of it on the spring photo forum post..and that was with only 3 people in the boat. normally if i surf i have more people. check it out
PostPosted: Fri Mar 22, 2013 4:18 pm
Thanks Dustin how do you keep it from rolling off the seats ??
PostPosted: Fri Mar 22, 2013 4:44 pm
haha, yeah i use the skybox seat since it comes out..or you can use a cooler..either way works. and the bag..people can just sit on that since it will not pop
PostPosted: Fri Mar 22, 2013 4:58 pm
Sweet sounds like I might have to demo that sack again
PostPosted: Fri Mar 22, 2013 5:30 pm
@ Dustin what are you running in the bow? SMG I run the 750's in rear and fill them full with no issues.
PostPosted: Fri Mar 22, 2013 5:34 pm
I also run the 750's in the rear and the 950 in the front works well but need a few people to get it real nice.
PostPosted: Fri Mar 22, 2013 6:04 pm
I run the same setup as Gibbs. Dustin's looks good with the 400 in the corner and the 1100 on the seat. I'm wondering how good it would be with my 750 in the corner and the 1100 on the seat.
PostPosted: Fri Mar 22, 2013 6:26 pm
i run the 950 full in the front. but for goofy i run no wedge down and reg i run with the wedge down. all due to the prop rotation...just know the 400 expands to 550 and i also put gear and other things in there that we bring on the boat..and take everything out of the other locker. its not to bad. has a nice curl at the end.its clean and also long and meaty. def check out the you tube vid called Wake Life and shows u more than the pics haha.
PostPosted: Fri Mar 22, 2013 8:41 pm
Dustin could not find that vid could you share the link to it.
