It is currently Mon Nov 23, 2026 1:32 am
 Post subject: Pic of full bow sac
PostPosted: Sun Apr 28, 2013 8:46 pm
I didn't feel like searching for the old threads. I took out the pnp fittings and put the regular sac fittings in. I fill it with a tsunami now. I weighted my boat today with the bow bag, the factory belly, and two 750s in rear. When I got into the water I drained the rear hard tanks to decrease the size of the wake a little bit. The wake was massive. I have not talk to Johnnie in a bit; however, I took his advice and left the wedge up. Biggest wake I have ever seen. This makes me want to stay with Axis and never buy a wakesetter because I am happy with the wake.
The boat popped up on plane promptly. It was funny because my inlaws were on the boat. i involved them with filling up the three sacs. Their faces were so funny when i talked about sinking. My 1235 has been rebuilt twice due to where we ride. I do know the characteristics are not at 100 percent anymore. It is more like 95 percent which is a significant difference. I still see no need for the 2315 yet. Next time I go out I am going to play with the wedge and compare the wake to a few different weight setups I have in mind. Seriously Axis owners, you absolutely need to slam the front with weight when you have issues getting on plane. I know people that have ran 1100s in rear and put the pnp sac under seats and ran a 1K bow sac full till it looked as if it would burst.
Gibby
2011 A22 Vandall
 Post subject: Re: Pic of full bow sac
PostPosted: Sun Apr 28, 2013 8:53 pm
Gibby
2011 A22 Vandall
PostPosted: Sun Apr 28, 2013 8:54 pm
Gibby
2011 A22 Vandall
PostPosted: Mon Apr 29, 2013 10:47 am
Same idea i had except i put this sac under the seat to replace it
I also ran ^^^^ w704 inline with stock tank and used left over fill and drain pumps to feed/drain bow sac when its on top of seat
PostPosted: Wed May 01, 2013 3:39 pm
Shoot some pics of the wake next time!
PostPosted: Wed May 29, 2013 12:16 pm
I just left that arrow sac in place and put a 400# sac in the aisle and one across the backrests of the bow to form a "T"40
Then a third 400# sac on the floor. Here's a video of that wake:
Axisowners
PostPosted: Fri May 31, 2013 10:44 am
Flatfive, Gibster whats your total ballast weight i think i have 3750 w/o wedge and 4750 w/wedge
PostPosted: Fri May 31, 2013 2:01 pm
I always have to add it up and I can never remember what the stock hard tanks are in the rear, 200?
So 200+750 pnp sacs = 950 in each locker
500 center tank
950 forward pnp
3350 of stock ballast, plus 800 in the bow and 400 on the floor: 4550
Axisowners
PostPosted: Fri May 31, 2013 6:25 pm
You're not really getting that much because the rear 750s can't fill all the way, and assuming you are leaving the 950 under the front seats, it is only filling to about 725 or so. I did the test on that last summer and will give you the link when I find it. Not sure how far the 750s really fill.
PostPosted: Fri May 31, 2013 6:28 pm
Here it is: viewtopic.php?t=863
