It is currently Tue Nov 03, 2026 8:04 am
Post new topic Reply to topic  [ 133 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14
PostPosted: Mon Jun 11, 2018 7:15 pm
Negative I never listed my t23 at all. Same with my current 23LSV I fill everything even and add lead. The t23 had a killer wave on both sides with about 4K in Ballast. The 2018 LSV I’m only running 350lbs over stock p&p and awesome.
PostPosted: Tue Jun 12, 2018 9:45 am
cbray4 wrote:
steveA20 wrote:
cbray4 wrote:
So we are just getting into a 2016 T23. The guy we are buying it from says it has rear PNP installed but no PNP in the bow. I emailed wakemakers to ask about what they had. They said they suggest putting a 400lb PNP bow bag in there. I see a lot of guys using 650's and 750's and some even more. Why would they suggest only 400lbs? Is that all that they have? Whats going on? I have read tons of threads saying the more bow weight the better, I want more bow weight!
The A20,T22 and T23 all share the same triangle P&P wakemakers triangle bag which is 400lbs. I run it in my 2016 A20 and spread around another 350lbs of wake ballast lead bags on top of the bow cushions. Wakemakers went to Malibu and did a laser measurement of all the boats rear lockers and under bow cushion areas where the front P&P bag goes and designed an exact fit triangle bag. When fully bulged I'm sure it holds a bit more but you gotta remember space is space and it doesn't matter if you run a flyhigh 1000lb triangle under there it's only gonna hold between 4 and 500 lbs. So the only way to get more weight in the bow is lead or fill another sac on top of the cushions.
Yeah I'm definitely interested in putting some lead behind the cushions up in the nose. Anybody seen any how to's on how to pull the back cushions off the bow seats?
i didn't remove any of my cushions in a 16t22 ( I just bought some cheep walmart tool bags similar to these
https://www.walmart.com/ip/Heavy-Duty-C ... 3=&veh=sem
(10 of them for about 5$ a piece and gave the guy at my local tire shop 20$ to take a bunch of the old tire weights off his hand sand filled them up. ( if the T23 is made the same way you can slide the bags right up inside the cup holder opening and push them into the nose. took me about 5 min. helps a lot with the wave! I'll post some pics this weekend
PostPosted: Tue Jun 12, 2018 4:48 pm
The bow bag in the t23 will only hold about 500lbs under the seats.
Users browsing this forum: Majestic-12 [Bot] and 80 guests
