It is currently Sun Oct 11, 2026 7:05 pm
 Post subject: Re: A22 2014 with moonson 350 need to decide
PostPosted: Sun Dec 27, 2015 10:10 am
Surfgate. This is a no brainer. It is easier to sell also.
PostPosted: Sun Dec 27, 2015 11:09 am
Fbeltrao wrote:
Having the 2015 A22 w/ 350 and a 2012 A22 w/ 450 which one would you pick? Both of them are in great conditions. Surf tabs only in the 2015, the rest of the options are pretty much the same. Many tks for the advice
There's more than just option differences to consider. The 2015 A22 is a newer, deeper hull with more freeboard. This also gives way more storage in the 2015. The 2015 has a cooler under the seat, the 2012 cooler will be in the way on the floor, although you could get a small (very small) soft side cooler to fit under the seat in the 2012 but that will take up probably 25% of your total underseat storage space because there's not that much. The surf wave on the 2015 is a lot better than the 2012...it's a no brainer here. The wakeboard wake in the 2015 vs 2012 are both amazing and easy to dial in and both very clean down to 18mph for new riders or kids. The gel coat seemed to get a little better starting in 2014 with cleaner lines. The upholstery is much better in the 2015 vs the 2012. The ballast system in the 2015 is much better (faster) with bigger lines and dual drain lines whereas the 2012 has smaller lines and only a single drain.
PostPosted: Sun Dec 27, 2015 11:44 am
Seems it is an easy question to answer. Tks for the feedback. Very much helpful!
Users browsing this forum: No registered users and 93 guests
