It is currently Thu Oct 29, 2026 8:41 pm
ThatGuy
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Sat Jun 20, 2015 9:39 am |
Joined: Thu Jan 08, 2015 6:29 pm Posts: 538 Location: Ohio
I just got my box with bags/connectors/engine wall support kit and they told me when ordering I needed 9 extra fittings and also 2 90* fittings. Hoping to install everything tomorrow pending weather!
_________________ 2015 T22 - SOLD
3oh2rider
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Sat Jun 20, 2015 6:27 pm |
Rear bags (750) worked very well. Unfortunately I didn't realize it didn't come with extra fittings. Did anyone trim their rear drain line? I feel like the bag and drain tube would sit better
gtesoro
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Tue Jul 14, 2015 9:01 pm |
What bow sac are you all installing that goes under the bow cushions in the 2015 t22? In my 2015 the only space under a bow cushion is under the center cushion. What sac fits there and how much weight?
ThatGuy
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Sun Jul 19, 2015 4:30 pm |
I put the Sumo 650 bag in mine. Not sure how much it fills but it lifts the center cushion up when its super full.
2015T22
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Tue Jul 21, 2015 6:04 pm |
| Boater |
I recommend 90 degree quick connect fittings for all three hoses on the bow sack. My dealer installed my fly high bow sack with straight quick connect fittings and it never filled/drained correctly and didn't hold much weight. Last week I replaced all 3 fittings with 90's. I hold considerably more water and it fills and drains better because the bag isn't getting pressure from the hoses. I feel like an idiot for running it with the straight fittings for so long. The surf wake is noticeably better with the extra bow weight and now I can see over the bow without standing up.
Mine lifts the center cushion up and seems to drain over time. I don't see water coming out the vent or drain thru hulls so I assume its slowly leaking past the check valve through the intake thru hull.
ThatGuy
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Tue Jul 21, 2015 7:55 pm |
I put 90* fittings on the vent and fill hoses but the drain comes straight up the starboard side and the bow bag drain port is right there as well so I just trimmed that line super short and stuck a straight fitting on there. Any pictures of a 90* on that one, wondering if that may be a good idea or not.
2015T22
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Tue Jul 21, 2015 9:58 pm |
| Boater |
thatguy,
The Fly High bag has the drain in the center of the back. With the straight fitting it pushes the bag forward in the compartment or pinching the bag off. That's why I wasn't able to fill or drain completely. It sounds like the fitting placement is better on the sumo bag.
ThatGuy
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Wed Jul 22, 2015 8:44 am |
Ahhh, makes sense. Thanks for that info!
Egreg3
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Sun May 08, 2016 10:04 am |
Hi all I got the bow sac on my t22 hooked up but it still doesn't fill, does it have a on/off valve like the back plug n play pumps.
3oh2rider
Post subject: Re: How to hook up bow sac on 2015 axis T22 Posted: Sun May 08, 2016 8:21 pm |
No valve. The pump is under the center hatch near the t handle drain plug. Make sure all connections are tight and pump is operational. The pump might be air locked and would need priming
Users browsing this forum: No registered users and 62 guests |
