It is currently Thu Oct 22, 2026 6:51 pm
 Post subject: Re: My new tower setup
PostPosted: Fri Mar 06, 2015 9:44 am
They look great on the boat..
PostPosted: Fri Mar 06, 2015 9:57 am
looks good man! hopefully I see you in Havi soon so I can hear it.
PostPosted: Fri Mar 06, 2015 8:32 pm
Thanks for the feedback. I pumped on them. They sound amazing. Although I wasn't expecting the weight of the tower with them installed.
I like them even more that they arnt wet sounds. Everybody has them!! I'm also surprised on how bright those little LED are. They light up the whole interior pretty good.
PostPosted: Sat Mar 07, 2015 9:12 am
I feel like I'm not completely ignorant on using these apps, but how in the world do I pose an original question on this forum? I can't seem to find the correct "button"!
PostPosted: Sat Mar 07, 2015 9:34 am
Are you on tapatalk or the web?
 Post subject: My new tower setup
PostPosted: Sat Mar 07, 2015 10:40 am
If you're using tapatalk you need to select a forum from the drop down menu at the top of the screen, then you can start a new topic by selecting the three small dots on the top right corner. It doesn't give you the option if you're just viewing the timeline.
PostPosted: Sat Mar 07, 2015 1:44 pm
That's the boat that pulled the 2013 Brostock comp.
PostPosted: Sat Mar 07, 2015 2:06 pm
Ha yep we bought it off Malibu June 2014. They really decked the boat out with some options not available at the time which is pretty cool.
PostPosted: Sat Mar 07, 2015 6:21 pm
Sweet tower set up!
A question, what LED lights did you use and when you drilled the new holes were you concerned about the tower integrity? I love the LED idea and I'm planning an Exile install in 2 weeks and I was thinking about an alternate location closer to the sides of the tower to not reduce the headroom.
Cheers
2009 A22
Wood Lake, BC, Canada
PostPosted: Sat Mar 07, 2015 6:59 pm
I used the boatmate runway led lights. I think they were right at $13 for one. It's a 5/8" hole. No, the tower is plenty strong. The tubing is 2 7/8" and it's pretty thick. I just tapped into the factory navigation light.
