It is currently Thu Oct 15, 2026 8:00 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Sub enclosure ideas.
PostPosted: Fri Jun 20, 2014 10:05 am
Yea, I have the heater, but it was mounted up pretty high. The biggest trouble was one of the heater vents and a long plastic tube housing that I had to be aware of. The area is huge under the dash. If you built a intricate box, you can get a lot of sq. footage under there. The floor is also pretty flat in there.
I built the box using screws and wood glue, applied resin, and also siliconed the seams, so it's completely air tight.
The sound is a huge improvement. It went from basically inaudible to actually hearing bass.
I knew the sub was just an entry level sub, with dual 4ohm voice coils. I wired it to 2ohms. The stock amp is 2ohm stable at 350watts rms, so I wasn't expecting heart pounding bass. I would say it's a perfect upgrade to the factory setup.
I also only used 1/2" MDF because that sub isn't capable of flexing the enclosure and with the box being only 17x17x8, it is already very rigid.
PostPosted: Fri Jun 20, 2014 1:08 pm
Here is an A20 our stereo installer (Dennis of Liquid Trends) just finished up for a customer. The boat had Sound Pack 1 and they wanted a simple upgrade more geared for surfing.
Everything is Exile Audio and it sounds great
PostPosted: Mon Jun 23, 2014 12:21 pm
How much improvement do you think it gave over the stock setup?
PostPosted: Mon Jun 23, 2014 12:39 pm
Good question. Was it worth the time to build everything for what you get in return?
PostPosted: Mon Jun 23, 2014 1:33 pm
Oh yes, it was a huge improvement over the stock setup. I think it ended up being about $50 is supplies and a few hours of my time. It was definitely well worth it.
I think I started building the box at 2pm and had it all finished, buttoned up, and stereo playing at 6pm. I really don't see how I could go wrong. It was only $50 and was a nice little hobby on my day off. The best part is, it still looks completely factory.
PostPosted: Mon Jun 23, 2014 2:19 pm
Are you getting and rattle or vibration noise from the factory panel where your sub box fits up snug to it?
PostPosted: Mon Jun 23, 2014 3:34 pm
Surprisingly, no. I mean if I crank the sub, other things under the dash will vibrate, but nothing between the box and plastic kick panel. You have to figure, I used 4 counter sunk screws to attach the sub box to the plastic kick panel. Those were offset from the sub screw holes. Then I used 8 longer sub screws to add even more strength.
PostPosted: Mon Jun 23, 2014 5:41 pm
Did you put anything under the box for support or is it hanging from the plastic panel?
PostPosted: Mon Jun 23, 2014 6:41 pm
I was just about to ask the same thing. Also, does it make it a lot tougher to get to your heater core to winterized it?
PostPosted: Mon Jun 23, 2014 6:43 pm
Sorry for all the questions. I just trying to ask everything I can think fr before I tackle this too. I dot want to regret it later if its a pain in the ass to do and undo a few times a year for not a lot of return in added bass. If its worth the extra effort to build the enclosure and undo everything to get to the heater core, I'm def doing it.
