It is currently Sat Sep 26, 2026 12:14 pm
 Post subject: Re: bluetooth adapter
PostPosted: Tue Jun 03, 2014 9:58 am
Smully wrote:
McGuire011 wrote:
Smully how did this end up working out for you? Definitely looking to get one!
I actually just hooked it up yesterday. They were on backorder everywhere. It works great and was a super easy install. Only bummer is when you turn the engine off and over to just the music setting my phone needs to be reconnected to the bluetooth. I need to rewire my stereo so it doesn't turn off when I turn the engine off so I don't have to deal with that issue. Other than that it sounds and works great.
I preferred the way that my Centurion was setup, they had the stereo on a dash switch.
PostPosted: Tue Jun 03, 2014 10:04 am
I preferred the way that my Centurion was setup, they had the stereo on a dash switch.[/quote]
Could you wire the stereo into the acc switch on the dash if you haven't already wired anything into it?
Sink Responsibly
PostPosted: Tue Jun 03, 2014 10:48 am
Has anyone gone this route? Looks like a pretty good idea.
http://airenabler.qnology.com/videodemo
PostPosted: Tue Jun 03, 2014 8:35 pm
Could you wire the stereo into the acc switch on the dash if you haven't already wired anything into it?[/quote]
Yeah should be really easy to do that
PostPosted: Tue Jun 03, 2014 8:53 pm
My stereo is wired into a toggle switch. Got tired of the music stopping when I turned the boat off and turned the switch back. IMHO having it wired into the toggle switch is the way to go.
PostPosted: Tue Jun 03, 2014 10:32 pm
How do you do that if you don't mind me asking?
Sink Responsibly
PostPosted: Wed Jun 04, 2014 12:35 am
I actually had my dealer do it and he said it was a little more difficult than he thought it would be. I am not sure what he meant by this. Was it harder to figure it out or harder running the wires, etc.? I will get under the dash this weekend and look it over and try to figure it out and post pics and stuff here for people wanting to do it.
PostPosted: Wed Jun 04, 2014 10:35 am
Thank a lot bama axis!
Sink Responsibly
PostPosted: Wed Jun 04, 2014 10:38 am
It really depends whether or not the ACC switches are hot or not. If they are wired and capped, it would just be a matter of clipping and capping the wire that goes from stereo to ignition and connecting a wire from the ACC switch to the IGN wire coming off the head unit.
PostPosted: Wed Jun 04, 2014 10:39 am
If the switches aren't wired at all, then you would need to pull a wire from the fuse block to the switch and get that all setup.
