It is currently Thu Oct 30, 2025 3:59 pm
 Post subject: Need new rca cables
PostPosted: Mon Aug 20, 2012 7:18 am
Hey guys, I just found out one of my stereo's rca cables went bad this weekend. I'm going to just go ahead and replace all three stock cables at once and I'd like to get it all done by labor day. Does anyone know what length cable I will need? Any cable recommendations? Thanks in advance.
 Post subject: Re: Need new rca cables
PostPosted: Mon Aug 20, 2012 12:01 pm
I ran 20' ones, and they are a wee bit short. HOwever, I've got an EQ and I made my own amp panel, so YMMV. I have the cable pulled really tightly now to run my tower speakers (fathest away amp). I am going to relocate my EQ to the starboard side, which should give me a bit of slack, which would make it just long enough.
Hint for running the new ones, get some of the fiberglass rods they sell at Home Depot for running electrical cable, remove the AXIS logo triangle in the front center, then you can pop off hte cushion, and feed the rods through that way.
PostPosted: Mon Aug 20, 2012 12:07 pm
Are you referring to plastic conduit on the "fiberglass rods"?
PostPosted: Mon Aug 20, 2012 6:56 pm
Not sure what you mean. Conduit is a tube through which cable is run. These are to help you run cable:
http://www.homedepot.com/webapp/wcs/sto ... =100660162
PostPosted: Tue Aug 21, 2012 7:09 am
ok gotcha, I thought you were talking about putting conduit in the boat to run the wires through. Thought that might be going a little over board! LOL
Users browsing this forum: No registered users and 253 guests
