It is currently Sun Mar 22, 2026 7:11 am
 Post subject: 2015 A20 330 No ECM Data
PostPosted: Mon Jul 06, 2020 4:45 am
I’m getting a “no ecm data” when the ignition switch is on the ON position. Everything on the dash looks fine for a second until the error comes up.
If I try to start the engine nothing happens all, no crack nada.
Radio, pumps, blower all work fine, which I would think batteries are good??
Boat was fine last weekend, no issues at all.
2015 A20 330
Thanks in advance
 Post subject: Re: 2015 A20 330 No ECM Data
PostPosted: Mon Aug 02, 2021 9:05 pm
We're you ever able to figure out the cause of your problem? I have a 2018 T23 that says no ecm data and won'tstart.
PostPosted: Sat Oct 02, 2021 3:42 pm
my 2013 a20 had similar issue. code for low voltage at pcm. pcm relay was bad, just ordered some on amazon.
Users browsing this forum: Google Adsense [Bot] and 47 guests
