It is currently Sun Nov 08, 2026 11:40 am
 Post subject: Added Fatsacs to my T23
PostPosted: Mon Jun 18, 2018 10:14 am
So we purchased Fat sacs for the boat but have a few questions.
1- The fill hose coming from the hard tank is about a foot long, Do I need to shorten it to allow the bag to go back more?
2- If I shorten the fill hose the bottom front hose is going to be short it is already up under the seat. Do I add onto that one? I believe I would just need a 1.125 barb fitting and just use what I cut off the back end.
3- Of coarse there is no disconnects up front after removing the Y. What fittings does everyone use?
4- Is it recommended to install the side panel braces?
Thanks!!
 Post subject: Re: Added Fatsacs to my T23
PostPosted: Mon Jun 18, 2018 10:22 am
Thanks!!
I have a t22 with 750s in the rear. I did have to cut my piping back for the bag to lay flat. I don’t recall adding any. I don’t know how your pipes come through. My hoses run together up the starboard side of the boat. I used all 90s to connect the bow bag. If I recall anything over 900lb bags should have the side bracing. I didn’t add it with my 750 and have been fine thus far. Good luck
PostPosted: Mon Jun 18, 2018 12:17 pm
Thanks!!
What size rear fat sacs did u purchase? What year is the boat?
PostPosted: Mon Jun 18, 2018 1:22 pm
Didn't think about that.... 2015 T23 purchased 1100# rears and nobody really gives the weight for the bow sac. What size is the tubing? 1.125 if my memory is correct.
