It is currently Sun Mar 22, 2026 12:39 pm
Post new topic Reply to topic  [ 11 posts ]  Go to page Previous  1, 2
 Post subject: Re: Rear Ballast - Removing hard tanks and running 1100 only
PostPosted: Sun Apr 15, 2012 7:09 pm
Mine wernt glued but definatly to long to get out without cutting.
I think may have figured out a way to get the factory pump to drain everything better. If you T into the overflow line connecting the bag and the tank and then T into the the drain pump. Then you just connect the T from the overflow line to the T in the pump. When the water in the bag will then overflos to the right into the tank and also to the left directly into the drain pump. when you flip the switch the pump will be getting water from the tank and directly from the bag at the same time. Ill try and get some pictures up when im done. I feel like my expanation is hard to follow.
Users browsing this forum: Majestic-12 [Bot] and 78 guests
