It is currently Fri Mar 27, 2026 3:35 am
Post new topic Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bow Bag Auto Draining and Bow Drain Pump Doesn't Work -
PostPosted: Mon Aug 08, 2016 4:16 pm
I was out today and noticed that if I don't vent the bag when filling, it doesn't siphon drain while using it, but for it to drain totally when your done you have to top off and vent then drain.
PostPosted: Fri Aug 12, 2016 7:27 am
My bag siphons out the fill pump too; even past the check valve. Waiting for winter to "dooshay engineer" an improved solution.
The negative pressure on the fill side is much stronger than the factory CV can handle.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 34 guests
