It is currently Fri Mar 27, 2026 4:18 am
 Post subject: Tower mirror
PostPosted: Fri Jul 22, 2016 8:31 am
I like my tower mirror,but I need to fold it for storage on my hoist, does anyone know of any company making removable/folding brackets that fit the axis tower? I found quite a few online but they all seem too short. I really don't want to go to a window mount.
 Post subject: Re: Tower mirror
PostPosted: Fri Jul 22, 2016 9:04 am
Maybe find the thread pitch and diameter and get longer bolts with washers and hand turned knobs? Just a thought. I haven't seen anyone do any mods before but it should b pretty straight forward.
PostPosted: Fri Jul 22, 2016 10:20 am
or a locking cam lever?
http://www.mcmaster.com/#cam-levers/=13e7gqr
PostPosted: Fri Jul 22, 2016 11:04 am
Those are both good ideas, and they both crossed my mind, but I was hoping to not spin the clamp on the tower( 40 hrs on boat and already wearing on tower powder coat from spinning ). If I can't find something with a clamp and pivot, I think I will cut and mill a pivot point in the stock arm over the winter. I just thought if there was something already out there I'd like to see it. Thanks for the ideas guys, this is the reason I like this board.
PostPosted: Fri Jul 22, 2016 11:20 am
Put a rubber layer between the arm and the lower. It will cut down of the wear and tear.
PostPosted: Fri Jul 22, 2016 3:06 pm
A slice from an old busted water hose should work well. You won't see it anyways. A little dab of silicone gasket maker rtv should keep it held in place
