It is currently Fri Mar 27, 2026 4:17 am
 Post subject: A22 problems with motor dying crossing waves
PostPosted: Thu Jul 14, 2016 12:01 am
Hey guys, I have loved my 13 a22 recon edition since the day I bought it. Have really had no troubles at all other than minor plug and play issues that I sorted out easily enough.
My boat sits in a marina 99 percent of the time, but I decided I would haul my boat to work with me for this 2 week shift. Once here I've only gotten it out once due to crap weather.. but while cruising around exploring the lake I went to cross my own wake and the hull hitting caused the motor to die completely. This is at speed like 30mph. It fires right up again every time. But without fail now it dies every big bump. I'm assuming it's a loose electrical connection to the motor somewhere? Any ideas what plugs to start checking? The gauges all stay on and lit up so I don't think it's the key ignition connection cause I would think they would flash on and off quick. Please help I'd love to get the sorted asap before my 3 week holidays!
Sent from my SM-G920W8 using Tapatalk
 Post subject: Re: A22 problems with motor dying crossing waves
PostPosted: Thu Jul 14, 2016 12:18 am
Be sure to check the kill switch and the distributor and spark plug connections. Sorry I'm not much help.
PostPosted: Thu Jul 14, 2016 5:36 am
I would check the ECU plug/snap connector and battery cables. Just get it started and shake stuff until it repeats the problem. Electrical gremlins like this are the absolute worse. Good luck.
PostPosted: Thu Jul 14, 2016 11:19 am
Yeah. I kind of wiggled the 3 big plugs that go onto the computer right on top of the vdrive, wondering if there was any other connections I should be checking out as well. Argh haha.
