It is currently Fri Mar 27, 2026 7:35 am
 Post subject: 2013 Axis A22 bag and surf gate set-up
PostPosted: Wed Jun 29, 2016 12:48 pm
http://api.viglink.com/api/click?format ... botAWd0yM-
I finally got around to ordering my bags and surf gate set-up. This is what I ordered above as well as the Delta Universal Surf Gate Tab from Mission Gear!
http://www.missionboatgear.com/collecti ... surf-panel
I will run this and see how the surf wave acts.....can't wait to throw the rope in the boat!
Any suggestions on installation? I have the plug and play system installed when the boat was ordered but I ordered the fitting package with the bags just in case!
Also I know I will need another prop soon! ACME 2315 correct?
Adrian Way
 Post subject: Re: 2013 Axis A22 bag and surf gate set-up
PostPosted: Wed Jun 29, 2016 5:44 pm
OJ 945 Pulls like a beast.
PostPosted: Thu Jun 30, 2016 4:34 am
My advice is call OJ (they were great to work with) and/or ACME and talk through with them your exact set up and get the recommendation from the pros that do this every day. If I have learned one thing through trying to laser in my boat it's that what works for one person will probably not be exactly right for another's situation. Things like motor and elevation can make your exact need swing wildly from another persons exact need.
Toy Store:
2016 A22 Green/White
2009 Built Jeep Wrangler
1978 Bandit Trans-Am
PostPosted: Thu Jun 30, 2016 1:06 pm
I have 2012 A22 and surf with rear tanks and 750's full center tank and bow bag full, 400 bag on surf side seat, 325 bag on top of bow seats and a DIY surfgate and the 2315 works great.
PostPosted: Sat Jul 02, 2016 8:27 am
Installing these bags on a 2103 there is only one hose is the rear locker? I thought there was supposed to be 3? Also how in the world do you do the front sac? Not to plug and play in my opinion!
PostPosted: Tue Jul 05, 2016 2:55 pm
Can someone give me a little help with this bag install. And also the one bag I had in it the connector popped off how do you stop that?
PostPosted: Tue Jul 05, 2016 9:13 pm
Here is how mine were setup from the factory (drain times are really slow with factory setup)
Fill pump > bag top > bag drain > tank > tank drain > drain pump. Extra bag top is vent
I changed mine to Speed up drain times.
Fill pump > tank > Tank > bag top > other bag top > vent
Tank drain and bag drain > "T" fitting > drain pump > drain
Bags drain a lot faster but in hindsight I wish I would have just added a separate pump to drain the bag. It probably would have taken the same amount of time to install. Working in the lockers is a pain do it once and be done.
I may add dedicated pumps for fill and drain of bags at some point. Thinking about taking out my hard tanks and doing a dual drain dual fill setup to really speed things up.
PostPosted: Mon Jul 11, 2016 12:33 pm
Ok I understand the above but I need the easy stuff answered i guess.
Front bag arrow 950 sac has 3 connectioons I am supposed to have the plug and play where are the hoses? How do you hook these up?
Escentially the front fill and drain switch does nothing unless you add the front bag correct?
now the rear. I only see one hose to connect at the rear bottom of bag. It would partially fill and drain fine but I have to stopper the holes in the side of the boat to get it to fill all the way with only one hose connected. It drained fine and sucked the bag dry.
So I already have 1" hose stuff so how do we complete this set-up
Users browsing this forum: No registered users and 24 guests
