It is currently Fri Mar 27, 2026 7:20 am
 Post subject: Best gas caddy
PostPosted: Thu Jun 02, 2016 9:36 am
Was looking to see what everyone uses to fill up there boat?no gas pumps on my lake.
Thanks bill
 Post subject: Re: Best gas caddy
PostPosted: Thu Jun 02, 2016 9:38 am
I own 16 of these: http://www.lowes.com/pd_786616-82393-SU ... 0007201001
But if I wasn't trailering my boat and had no gas on my lake, I'd probably put a big tank in the back of a pickup.
PostPosted: Thu Jun 02, 2016 9:51 am
I don't want to trailer my boat 10+ miles to get gas and I don't want to pay the $1+ extra to get it on the lake so I put this in he back of my truck, strap it down, fill it up, then bring it back and fill up my boat. The hand crank kinda sucks but only takes about 4-5 minutes to empty the tank.
http://amzn.to/1VzyNCm
PostPosted: Thu Jun 02, 2016 10:31 am
This is what I use at the lake. I have two 15 gallon jugs from flow fast with hand crank transfer pump. Really quick to refill the boat and get back on the water!
Sent from my SM-N900W8 using Tapatalk
PostPosted: Thu Jun 02, 2016 12:30 pm
They both look great.any issues with leaking?
Thank you bill
PostPosted: Thu Jun 02, 2016 12:56 pm
No issues with leaking. the cap is sealed by an o-ring. The pump works really well, very good quality and very fast. I can empty both 15 gallon jugs in about 5 minutes
PostPosted: Thu Jun 02, 2016 2:11 pm
No leaking at all on mine either. The cap creates a good seal. Also the pump can be turned in reverse once you're filled so whatever is left in the hose is put back into the tank. No spills!!
