It is currently Fri Mar 27, 2026 7:14 am
 Post subject: Re: Rear compartment won't drain
PostPosted: Wed Mar 23, 2016 8:03 am
Good news! Hopefully that's the only hiccup you have. Enjoy the boat!
PostPosted: Mon May 30, 2016 5:24 am
What's the simplest/quickest way to access the left rear drain pump?
PostPosted: Mon May 30, 2016 7:27 am
Remove the plastic covering it closest to the transom should be 3 or 4 screws and will lift straight off and the pump is there screwed into a fitting that goes into the hard tank
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 72 guests
