It is currently Mon Oct 26, 2026 8:49 am
 Post subject: Re: Rear ballast question..beat to death.
PostPosted: Sat Feb 20, 2016 3:23 pm
900's on my T22 without issues.
PostPosted: Sat Feb 20, 2016 4:18 pm
AJWest wrote:
FlyZoneCR wrote:
Not sure, but supposedly...
My partner had everything installed at gosurfassist.
Here's a video with info about ballast below it:
https://www.youtube.com/watch?v=jRFCMmoTTrQ
Sumo doesn't make a 1000 to my knowledge, 900's are the biggest, and not even on Straightline's (maker of Sumo) website.
I had never seen them or heard of 'm, but check 1:27 in this video
https://www.youtube.com/watch?v=wXOdqah ... e=youtu.be
Does look like Sumo 1000's somehow!
FlyZone Costa Rica Wakeboarding. 2011 A22 coming this way!
PostPosted: Sat Feb 20, 2016 5:21 pm
Interesting, Wakemakers has updated their website with new Sumo products. I like the black bags vs the gray ones. Had black Flyhighs in my other Axis. Straightline hasn't even updated their website yet with new ballast bags.
PostPosted: Sat Feb 20, 2016 5:34 pm
I see what Sumo did after reading the specs on the new Sumo Max black bags compared to their gray bags. The older 600 has the same specs as the new 650; the older 750 is the same as the 850; finally the older 900 is the same specs as the 1000. About 2yrs ago an extensive test was done on Sumo and Fly-High bags. The Fly-Highs were found to hold less than advertised except 1 bag. On the other hand, Sumo's bags all held MORE than advertised. I bet Sumo had to sell out on the stock of older gray bags and just renamed the new black bags with the accurate weights...makes sense especially when real numbers makes a difference because the Sumo 900 does hold 1000lbs, whereas the Fly-High 1100 only held 975-1000lbs.
PostPosted: Sun Feb 21, 2016 10:14 pm
I run flyhigh 750 bags in the rear lockers on my 14 A22, Absolutely love them! this is my third season running with these bags. they seem to fill all the way and are very durable haven't had any problems with seams or fittings leaking. wake is awesome!
