It is currently Sun Mar 29, 2026 11:26 am
[ 6 posts ] |
jason427
Post subject: HELP diagnose SERVICE ENGINE issue!!! Posted: Fri Aug 21, 2015 7:50 pm |
| Boater |
I just got boat back from it's first service and on way back to the dock cruising full out for a few minutes I get a SERVICE ENGINE message and rpm's drop down. I noticed coolant was at 190 degrees. My thoughts are the coolant is low, I will check in am when it is cool and fill if needed. Any other ideas? No fault codes were thrown on the gauge screen when I checked that.
Would low coolant cause this to happen with no fault codes?
Please advise, I have people coming from out of town on Sunday to use the boat and now this... bummer.
Jason
2015T22
Post subject: Re: HELP diagnose SERVICE ENGINE issue!!! Posted: Fri Aug 21, 2015 8:08 pm |
| Boater |
You need to be quick to get the fault code. Do you have a freshwater cooled motor with a closed cooling system? With a brand new boat why would the coolant be low? I think its much more likely that you have a plugged cooling system but most of us are raw water cooled so you may not get a ton of response here.
jason427
Post subject: Re: HELP diagnose SERVICE ENGINE issue!!! Posted: Sat Aug 22, 2015 11:47 am |
| Boater |
I topped the coolant off this morning and it didn't really take much at all so that might not be the issue. However both times yesterday when I was having the issues it was while running full out which I hardly ever do. about 5500rpm's. I did notice in the manual it mentioned max range should be about 5200 I think... Not sure if that was the issue. (it's a Monsoon 350) I took it out this morning and simulated surfing for a while with no issues. So I guess I will be good to go tomorrow and keep a close eye on things. Jason
JayMan
Post subject: Re: HELP diagnose SERVICE ENGINE issue!!! Posted: Sat Aug 22, 2015 3:37 pm |
Joined: Mon Oct 15, 2012 2:46 pm Posts: 490 Location: NW Arkansas
Some 2015 350 owners needed to update their ECM's due to exhaust temps being set incorrectly.
Walter
Post subject: Re: HELP diagnose SERVICE ENGINE issue!!! Posted: Sat Aug 22, 2015 7:20 pm |
That's the boats way of telling you to take it easy lol
Tnbrooks01
Post subject: Re: HELP diagnose SERVICE ENGINE issue!!! Posted: Sun Aug 23, 2015 9:25 pm |
Need to have the software flashed. Our dealer has had to do this to every 350 monsoon they have received this year. Something to do with exhaust temps reading incorrectly.
[ 6 posts ] |
Users browsing this forum: No registered users and 60 guests |
