It is currently Sun Mar 29, 2026 2:10 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: T23 -- (I'm Back!)
PostPosted: Wed Apr 22, 2015 6:57 pm
Would love to see the interior pictures. Did you put some green trim on the seats?
2015 T23
PostPosted: Sat May 02, 2015 3:15 pm
alexandera wrote:
Put 3.6 hrs on her sunday. 2313 prop 350. 3000 rpms no ballast cruised about 15/16 MPH. Tractor gears are beast! Top speed around 28/30, but it was windy as hell.
Listen up all you Indmar guys, be certain you read the break-in procedures for PCM... Totally different than Indmar, nearly 100 percent opposite!
23 caught a lot of looks and the fideen is banging!
How is the 2313 prop working out?
2015 T23
PostPosted: Sat May 02, 2015 7:43 pm
Is the 15 mounted under the dash? Im debating an L7 15 but am not sure if it will fit under the dash.
Joey
2012 A22
PostPosted: Sun May 03, 2015 7:20 am
Adam's 15" sub is sealed under the dash
PostPosted: Sun May 03, 2015 7:40 am
Prop seems overkill with the new gear ratio imo. Has torque for days and limited top end speed. Bet there's a happier medium.
