It is currently Thu Jan 09, 2025 9:44 pm
 Post subject: Mounting a WS420
PostPosted: Tue Aug 07, 2012 6:17 am
I'm mounting and hooking up my WS420 equilizer tonight. Just wondering how you all mounted yours. Pictures would be helpful. Thanks for all the help.
 Post subject: Re: Mounting a WS420
PostPosted: Tue Aug 07, 2012 10:11 am
I bought this mount on e-bay..It works really well.
Chad
2010 Axis A22
PostPosted: Tue Aug 07, 2012 10:41 am
Cut a hole in the area underneath the reciever. Cut the plastic more than the vinyl wrap so I could push the vinyl back in. Worked okay, I'm not as happy with it as I had hoped. It gets bumped a lot which switches it from main to aux. Will try to get pics in a few days.
PostPosted: Tue Aug 07, 2012 5:23 pm
I mounted the exile ZLD under the throttle in the storage tray area. Pull the panel mount a block on the fiberglass mount the eq. Cut a bit of the storage area to fit and reinstall.
PostPosted: Wed Aug 08, 2012 5:31 am
Thanks for the replys so far. I looked at it last night and I really want to mount it right under the stereo on the dash. But my question is what kind of bracket did you guys use to mount it under there. There isn't much to support it under the dash. Thanks for all of your help on this!! Hopefully I will get it all hooked up tonight!!!
PostPosted: Wed Aug 08, 2012 6:49 am
Honestly, mine is tight enough where it just stays. I'm still sorting out a lot of my install, it has been one of way too many projects this Summer. The plan is to run brackets off of the head unit (mine is a Clarion M502) and down, and bolt to it. But I have to say, if I could do it over, again, I'd put it where either Huddy or Chad have theirs. The knobs and switches routinely get bumped when getting into and out of the seat. On the right side, it is easy enough to adjust the boat/tower volume levels when necessary, but stays out of the way so the stuff you want to set and forget isn't screwed up all of the time.
PostPosted: Sun May 11, 2014 11:57 am
What year is your boat? The dash changed in 2013. Mine is located on the right side of the steering wheel.
I'll take a better picture of the mounting bracket tonight.
PostPosted: Mon May 12, 2014 6:00 pm
Users browsing this forum: Google [Bot] and 36 guests
