It is currently Thu Jan 09, 2025 9:42 pm
 Post subject: Re: Critique my wakeboard ballast setup
PostPosted: Mon May 05, 2014 9:46 am
Bama Axis wrote:
2012 A22
Factory tanks full
Wedge down
Fly High 950 up front.
Sumo 600'2 in the back.
Definitely going to need the prop upgrade.
Yeah, we ordered it with the torque prop upgrade.
PostPosted: Mon May 05, 2014 2:47 pm
I wonder what the 750 actually get to? I know the front of the bag is hindered a little but the back can swell and we all know the fly highs swell over given weight if given the room
PostPosted: Wed May 07, 2014 11:38 am
guys on WW did a side by side comparison with flyhigh, straightline sumos and ronix. They found the flyhigh 750's were only about 720 i think. you can search it on ww and get the exact numbers. They also found that the sumo 600's would fill to about 650 if i recall correctly.
With that info i know that my flyhigh 750's fill to only 650 in my lockers of my A22. I know this because last year I put one sumo 600 in one locker and one flyhigh 750 in the other. They filled at about the same rate, the sumo 600 filled completely full and did not put any pressure anywhere in the locker, the flyhigh 750 get squished under the access panel and does not fill all the way. The wake was evenly ballanced with both those sacks in my boat, so i can safely assume they are approx. the same weight.
