It is currently Mon Jan 06, 2025 12:55 am
 Post subject: "Auto Volume Control" feature
PostPosted: Fri Jun 21, 2013 12:44 pm
I see this feature listed everywhere on Axis' site.....is this a part of the factory Sony radio? I don't see it in the manual and it would be amazing if it was like my old car where whenever you slow down the volume drops to a pre-determined volume, and when you speed up across a thresh-hold set by the user the volume increases to a pre-determined volume.....
does this exist on our radios? If not what is this feature alluding to?
 Post subject: Re: "Auto Volume Control" feature
PostPosted: Fri Jun 21, 2013 2:13 pm
The adjustment is in the gauge cluster not the radio and I am not sure it comes with stereo pack 1.
It works sort of like you described. It simply raises the volume from the currently set position as you accelerate and then lowers it back to that position as you slow down. I think the settings are off, low, medium and high for the amount it changes the volume.
PostPosted: Fri Jun 21, 2013 3:10 pm
I have not seen it within my gauge cluster. I have stereo pack 2 and would like to use this feature for sure.
PostPosted: Fri Jun 21, 2013 5:17 pm
I think it might be a 2013 feature.
PostPosted: Fri Jun 21, 2013 5:53 pm
mine is 2013 and stereo pack 1.....have not seen it on the main gauge but ill give the dealer a call and mess with it a bit more. figured it was part of the radio so ive been looking in the wrong spot.
thanks!
PostPosted: Fri Jun 21, 2013 10:34 pm
I have a 2012 with Stereo Pack 3 and it is not on there.
Friends of ours had a 2013 Vandall and it was on theirs. Pretty sure they did not have Pack 3 either.
PostPosted: Sat Jun 22, 2013 1:43 am
Son of a.....ill have to mess with it on Sunday. Anyone have the option that can tell me where to control it? Same gauge I have everything else? Depth finder, temp, etc.??
Users browsing this forum: Google [Bot] and 52 guests
